I found while driving my own EV that, if I hold the accelerator down too long, the motor draws a lot of current and the battery voltage sags low. The car simply will not go any faster under these conditions but, if I lift my lead foot off of the pedal for one second, the voltage lifts, the motor operates in regenerative mode and the car will again accelerate forward at peak performance for another 3.5 seconds when I put the pedal down again.
Well OK but, who wants to constantly pump the pedal like that so, knowing this to be the case, I created a circuit that pulls back the accelerator by a percentage for one second every 3.5 seconds. I have the AC-50 motor, Curtis 3 phase controller with regenerative mode. This circuit is aided by a metal box of very large capacitors in the trunk space that can quickly absorb the charge during regenerative mode. The effects are subtle but, the driver can feel the bursts of acceleration each time the cycle completes. The car goes up hills better and generally performs better than before when the batteries are weak. I have been able to get up to speed using no more than 200 amps which saves the batteries. 500 amps is the peak for the motor and controller. I was very glad to have this working on my last 63 mile test drive. I will share more of this experiment soon. I have not tried this in any other car or with any other motors or controllers.
The secret to going farther is to not discharge the batteries too quickly.
Many electric car manufactures are working on coasting technology which is somewhat different than what I am doing here. There are ways of reducing the discharge of the batteries or at least the big guys that build cars believe it. Coasting is exactly that. The vehicle freewheels down hills and by inertia at times during which there is no drain of energy from the batteries.
